So I installed a new walbro gss341 255lph fuel pump. It works but I noticed it draws more current than the stock fuel pump fuse is rated at. I have an obd1 s52 swapped e30. So stock fuse is 7.5 amps but the walbro draws about 7.6 amps at idle. According to walbro it will draw 8-10 depending on fuel pressure. Would I need to increase my fuel pump fuse size? If so, how much can the stock wiring handle? I do not want to fry anything.
Walbro 255lph
Tags: None
Use the stock wires to activate a relay. I placed my relay by the trunk battery and ran new wires from the relay to the fuel pump..So I installed a new walbro gss341 255lph fuel pump. It works but I noticed it draws more current than the stock fuel pump fuse is rated at. I have an obd1 s52 swapped e30. So stock fuse is 7.5 amps but the walbro draws about 7.6 amps at idle. According to walbro it will draw 8-10 depending on fuel pressure. Would I need to increase my fuel pump fuse size? If so, how much can the stock wiring handle? I do not want to fry anything.88 e30/s50 gt35r turbo m3
96 gt4094r turbo m3
452 rwhp, 455 rwtq at 14 psi 91 octane
681 rwhp, 684 rwtq at 25 psi E65 -
