As the title states. I just pulled the motor and trans from a running and driving manual 1997 M3. I pulled the motor with the wiring harness still attached to the motor but I have heard and read that there is possible security system(ECMS?) that also needs to come with the car. My friend has the flashed/modded ECU that he is passing off to me, I'm unsure if this resolves this issue.
Is there anything else in the car that I need to pull that is crucial to the swap before I send the car to the junk yard?
Thank you,
Thank you,
