M50 rattle noise
  • Blake23
    • Jan 2017
    • 54
    M50 rattle noise
    Hi there,
    Ive got an M50 in my e30 and theres rattling from the front of the head. I have done the VANOS, swapped out the lower and upper tensioner with some used parts and its still there.
    Its marbles/rattle at about 2000rpm.
    Before i go out and buy a new timing chain, diaphragm springs and new tensioners i thought id see if anyone had any ideas.
    THanks
    Blake
  • pazi88
    • Sep 2015
    • 584
    Originally posted by Blake23
    Hi there,
    THanks
    Blake
    Did you upgrade the vanos to later m52 one? If not, do that and the noise will go away. It has spring washer which m50 doesn't have and that pushes vanos sprocket making it unable to produce rattling noise ä.
    • AndrewBird
      The Mad Scientist
      • 11897
      Yes, when you say you've done the vanos, what exactly have you done? Just seals won't make it not rattle.
      The upper tensioner on mine was bad and would make the chain rattle. Changed that out and the rattle went away.
      • Blake23
        • Jan 2017
        • 54
        Seals and little ring from Beisan
        • pazi88
          • Sep 2015
          • 584
          So the noise is probaply because it needs the upgrade.
          https://www.realoem.com/bmw/enUS/sho...diagId=11_6060
          M50 is missing parts 10 and 11. To upgrade to m52 vanos, get 11, 10, 9 and 3pcs of bolt 6.
          • Blake23
            • Jan 2017
            • 54
            I have purchased the spring plates, a new chain and a new upper tensioner.. While im there I thought id just replace what I can. I'll let you know how I go
            • Blake23
              • Jan 2017
              • 54
              No luck. Changed upper Tensioner upper chain and diaphragm spring and still no luck
              • AndrewBird
                The Mad Scientist
                • 11897
                That's not normal vanos noise, at least in my experience. That sounds more like the timing chain slapping around. Have you replaced the lower main tensioner? If you have, make sure the notch in the tension sits on the chain rail properly. If you don't get this lined up properly, it can cause issues.
                • Blake23
                  • Jan 2017
                  • 54
                  I replaced with another used one. I’m ordering a new one today.
                  • KIRIEIW
                    • Dec 2012
                    • 3385
                    Beisan Systems sells the M50tu rattle kit to fix vanos rattle. I just ordered a pair for my e46 today, unfortunately. The kit fix's the annoying marble like noise you can hear between 1800-2200 rpms.
                    1992 e34 Touring- S50 Swap
                    1992 325i-S50 Swap (SOLD)
                    1991
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      I just did a 1995 US s50 model on Thursday, had all those parts. Are you sure that's not a Euro-only thing?
                      In fact, I have done several at my shop over the years and don't remember any of them (m50's) missing that spring.
                      EDIT: Strange, if you do a cross-reference, it shows "only in conjunction with" on early models...
                      https://www.realoem.com/bmw/enUS/sho...41#11361403550
                      john@m20guru.com
                      Links:
                      • pazi88
                        • Sep 2015
                        • 584
                        Not sure about the US s5x engines, because we don't have those here. It could be even that BMW upgraded the vanos for those before regular models. But at least in euro m50/m52 models, the engines before 3/95 don't have the spring washer there. And later ones have. But the rattle on earlier ones that don't have spring washer normally goes away using the later parts with spring washer.
                        • razo-s.supra
                          • Dec 2009
                          • 124
                          I got to hear my M50 run before I purchased it. Heard an odd rattling but bought it any ways. Yanked it out and put it on a stand to reseal it all. I dropped the pan and sure enough chunks of plastic were lodged in the hole of the oil pick up. dead timing chain guide. Im not saying thats what is making the noise but its definitely a possibility as my m50 only had about 145k on the clock.
