Which valve stem seal do I need?
  • NEOe30
    • Jun 2016
    • 415
    So I have an m50nv with the 7mm valves and haven’t been able to find a valve seal that clearly states it’s for the 7mm valve. Can I use the standard 6mm seal, will it expand?
    If not where can I find the proper seal?
  • pazi88
    • Sep 2015
    • 584
    Why don't you just buy m50nv valve seals. Ebay is full of those. And if you buy full top end seal kit, those come with the kit.
    Also you can find bmw parts from bmw dealer if not elsewhere. That's where I buy my OEM parts.
    • TobyB
      • 5287
      Nope- you need the 7 mm seals.
      I would order 1992 bmw 325i valve stem seals from a reputable vendor.
      Blunt, etc.
      If you're really on a tight time frame, CALL Blunt. Steve will answer, or call you back.
      Then you'll be sure to get what you need.
      in my experience,
      t
      • NEOe30
        • Jun 2016
        • 415
        Appreciated, thank you
