Using AEM Wideband Signal as 413 DME Narrowband Signal
  • Sladek
    • May 2016
    • 228
    anyone know if this is possible? google and searching isnt turning anything up
  • haaken675
    • Sep 2016
    • 601
    I doubt it. The only way I could see this working is if you were to tune the ecu, and since you are obd1 that means with a chip, so not likely in this car.
    • Sladek
      • May 2016
      • 228
      even using the narrowband output from the AEM? I think it outputs the same voltage as the stock O2 sensor
      • pazi88
        • Sep 2015
        • 584
        The simulated narrowband output should work. But I haven't tested.
        • Sladek
          • May 2016
          • 228
          that's what I'm thinking but haven't found much info on it. and I don't want to be the guinea pig because I already hate wiring as it is lol
          • AndrewBird
            The Mad Scientist
            • 11898
            The whole point of the narrow band output is for this purpose, so it seems like it should work. I think most O2 sensors are 0-5v, so you should be good. Worst case is it just doesn't work.
            • TobyB
              • 5286
              If you want to test the narrowband output,
              just meter it. Below 14.7AFR, it should dive pretty quickly to 0v,
              over 14.7, it should climb to 1v.
              hth,
              t
              • Sladek
                • May 2016
                • 228
                guess imma give it a go and see what happens. the multimeter trick is good didnt even think of trying that
                • haaken675
                  • Sep 2016
                  • 601
                  hmm, I didn't realize the AEM wideband had a narrowband output. I have one that I havn't gotten around to installing yet, but I don't remember seeing that on the wiring diagram.I guess you learn something new everyday.
                  • Maad325
                    • Jan 2013
                    • 132
                    I ran my obd1 M52 with the narrow band output on my Innovate MTX-L through the signal wire on an old o2 sensor, left the stock sensor in so the heater circuit would work and not
                    throw a cel with the wideband. car ran fine but would start leaning out when running and the wideband was in heater. although there is no way to tell what the stock 413 afr scaling is for the 1v narrowband signal. car ran healthy afrs on a stock chip with 21.5 pound injectors and an m50 manifold
