S52 Clutch Not Disengaging
  • Sladek
    • May 2016
    • 228
    replaced the master (E30 M3) and slave (S52/E36) cylinders in my E30 with S52. now I can't even get the car in gear with the clutch in while the car is on. bled multiple times and the pedal is strong. everything worked relatively fine before replacing the parts. what am I doing wrong?
  • kronus
    • Apr 2008
    • 13029
    your slave may not have seated into the shift fork correctly
    cars beep boop
    • Sladek
      • May 2016
      • 228
      so that's what I originally thought but I lined it up to the indent in the clutch fork and there was solid pressure to install it
