Does E30 large flange ETA Driveshaft fit ZF320 trans?
  • reelizmpro
    • 9556
    Essentially, is the ZF320 trans shaft the same diameter as the Getrag 260? I'm trying to fit it but it doesn't seem to go on all the way by hand. I don't want to force it. Thanks.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
  • reelizmpro
    • 9556
    Just to update...the E30 and E36 DS both have the same PN for the guide bushing so it's a direct fit on the ZF320 provided the shaft is a large flange 96mm BCD like the E30 M3 and E36. I just had a bad angle or didn't use enough force to get it on but it's on now and lines up perfectly.
    88 M3 - LACHSSILBER
