M52 Vs. S50 piston pin location?
  • bimmer630
    • 1230
    Ive read that the M52 wrist pin location is higher in the piston than the S50 US piston.. . Anyone have the scoop on this?
    We are trying to use an M54 3.0 crank in an M52 block, We have a set of S50 rods and pistons.. The engine needs to be bored anyway due to an out of round cylinder.. so the larger s50 pistons would possibly be perfect, if they dont travel above the deck
  • digger
    • Nov 2005
    • 6193
    some data here but nothing for the s50
    you can still look up mahle catalog though
    s50b30US
    TecDoc Catalogue by TecAlliance - one of the world's leading global vehicle and spare parts catalogues for the automotive aftermarket based on the TecDoc standard.
    M52B28
    didnt have S52B32 data but i think comp height is 31mm from some aftermarket JE ones ive seen but this is an assumption
    So the s50b30Us has 1mm more comprssion height 32.8 vs 31.8mm
    i thought the block deck heights were the same M52b28/S50B30US/S52B32 at 210mm ?
    in which case you can just compare stack height
    M52b28: 42.0+135+31.8 = 208.8
    S50b30: 42.9+135+32.8 = 210.7
    S52b32: 44.8+135+31.0 = 210.8
    if you try
    44.8+135+32.8 = 212.6 = FAIL
    s52 pistons are what you need
