Quick wiring harness question - M50 (OBD1) to early c101
  • irish44j
    • 2763
    My e30 was originally an M10 car ('85) and I swapped it to M42 years ago.
    Anyhow, as I put the M50 wiring harness together, I have one odd-wire out that I'm not sure of. On the M50 harness there is a small black-with-green stripe wire that is listed in most places as "starter relay." Now, my M42 nor my M10 setup apparently used this wire, and there's no wire to run it to on the old square C101. Just the main starter wire (blk/yel).
    So, do i need to hook this up to something?
    Stage rally/rallycross e30 build/competition journal
    Track/street e21 build
    visit Condor Speed Shop
    visit Motorsport Hardware
    [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
  • TobyB
    • 5287
    Is it the signal to the unloader relay(s)? It would come off
    the 'hot' side of the starter motor if it was...
    t
    • irish44j
      • 2763
      t
      Not sure. I just checked my prior swap harness (for M42, which also has that wire) and found that I just dummied it off and didn't use it at all. So I guess it's something needed on the chassis side of later cars vice early ones like mine, or something. The starter worked fine without it (M20 starter with M20 FW in G240, for what it's worth).
      I'm going to leave a pigtail on the loom just in case.
      • irish44j
        • 2763
        Just to follow up, yes it's for the unloader relay. So, doesn't really need to be hooked up since this car has almost no OEM power accessories lol...
