Throttle body coolant line (S52)
  • svn2002s
    • Sep 2004
    • 486
    After installing the temp switch on the side of the head, what do you do with the port in the throttle body? Plug it? What about the other one?
  • Northern
    I like cupcakes & sh!tboxes
    • 5278
    On my swap, I cut the feed line from the coolant pipe like 0.5" from the base, crushed it flat, and welded it closed.
    The TB ports can just stay open. I don't think there's any way it could cause issues.
    Originally posted by priapism
    Originally posted by shameson
    • bradmer
      • May 2016
      • 362
      Since you are in California, you will need the throttle body coolant lines operational to pass bar for street use.
      • eternal24k
        • Jul 2017
        • 507
        why would they care? OP, you could always have a fake line going to the TB
        • bradmer
          • May 2016
          • 362
          They care, I was told the reason is that the throttle can get stuck wide open in freezing temperatures. I originally went with no TB lines due to having only 2 ports in the head but got called on it. I have since put a T in the line, easy to do and compliant.
          Good luck OP
