Low cost DIY ecu for m52/s52 (obd2)
  • Motheye99
    • May 2018
    • 853
    Can this the used on a M54 with a M50 intake and throttle body?
    this is awesome
    91' 318is 90' 325is
    Originally posted by Sonny
    Buy the E30s, they ain't gonna last long
    E30 can make you, E30 can break you
    "He who controls the Nova's, controls the Boomers"
    • pazi88
      • Sep 2015
      • 584
      Originally posted by Sladek
      do you think youll ever consider making an OBD1 version PCB for a "413" DME replacement? i know theres many people with OBD1 24v swaps that would be interested, myself included if I dont go through the process of swapping to OBD2
      or do you already have these created?
      Yes I have created those too. Works for many 88-pin Bosch ecus used by BMW. Like m40,m42,m43,m50tu,m50nv,m60:
      https://www.ebay.co.uk/itm/183990914454
      • pazi88
        • Sep 2015
        • 584
        this is awesome
        Yes if you swap in m52 wiring harness. But as I did previously post, I have m54/m52tu version coming.
        • Motheye99
          • May 2018
          • 853
          I want the manual throttle body for ITB action, and ready made M52 swap harness are cheaper How hard is it to setup a tune for one of these? I'm new to this ECU.
          91' 318is 90' 325is
          • pazi88
            • Sep 2015
            • 584
            Same as megasquirt. It even uses TunerStudio same way as megasquirt. So if you/your tuner know to tune megasquirt, speeduino can be tuned too. I also have the base tune available for my pcb's so no need to figure out all the settings etc. needed to make it run.
            • ForcedFirebird
              • Feb 2007
              • 8300
              This is great!
              I have a customer turbo m50 swapped e30 running on a stock DME where I just wrote a chip for, but would much rather SD tuning than MAF.
              About how long does the assembly take? Do you have a link for a list of components needed in addition to your board?
              john@m20guru.com
              Links:
              • Motheye99
                • May 2018
                • 853
                So If i wan too run this on a M54 and use a M50 intake and obd2 M52 wiring conversion your current board should work? I really don't car for DISA or the E throttle because I'm going to get rid of it eventually.
                91' 318is 90' 325is
                • pazi88
                  • Sep 2015
                  • 584
                  Originally posted by ForcedFirebird
                  This is great!
                  It takes about 2 hours for me, but it all depends how experienced you are putting together electronics. All that you need is here: https://github.com/pazi88/Speeduino-M5x-PCBs
                  I will soon update BOM little bit for more reliable 60-2 trigger wheel reading, but it will be only few regular passives that will change.
                  • Sladek
                    • May 2016
                    • 228
                    damn looks like the P7307-ND part on the OBD1 BOM is on backorder till mid-Feb. guess ill just have to wait unless your new trigger wheel reading replaces this part haha
                    • pazi88
                      • Sep 2015
                      • 584
                      There is tons of alternatives for that like, MOV-14D220K-ND, 495-6523-1-ND, 495-6522-1-ND etc.
                      • Sladek
                        • May 2016
                        • 228
                        Oh nice! i dont know a whole lot about electrical components at this level so good to know there are alternates that can be used without damage
                        • Balleristic31
                          • Aug 2009
                          • 4198
                          Pazi, sent you a PM regarding an M42 ecu.
                          -NICK
                          • Sladek
                            • May 2016
                            • 228
                            Do you have any S52 base tunes?
                            • pazi88
                              • Sep 2015
                              • 584
                              The m52 base tune works on s52 too. Just calculate the req. fuel to suit the engine.
                              The base tune is just to have correct settings and some kind of feasible maps to make the engine run and idle. From that it's easy to start tuning the engine or take it to dyno to be tuned by professionalwhich is the recommended way :D
                              • DesertBMW
                                • Aug 2011
                                • 1030
                                where to buy boards?
