Hi guys,
I am looking for the right gearbox for my M52B28 swap which will straight bolt up to my M52 engine, so I could use the stock 320i crossmember mount, shift linkage and driveshaft of my E30.
Found out the G240 from a 318is will be the right gearbox for this.
The G240 from my E30 320i which I have will be mounted under a different angle.
Now I also do have a G225 (#PN 220.0.0225.97) in house. I couldn't find a lot of info about using this one. Should my G225 bolt up easily without modifying the crossmember mounts and shift linkage?
If someone could answer this question I know if I have to look for a G240 318is gearbox or could start preparing my G225.
