E30 M50 Non Vanos erratic idle
  • NvE30
    • Apr 2019
    • 48
    The engine idles erratically with MAF plugged in, and idles perfect with it disconnected. So i replaced the MAF with a brand new one and no change. I tried a different ICV that i know is working and even a different TPS and i even tried a another DME with no luck. I also checked for vacuum leaks and there are none. Worst case i'll just run it without the MAF. Any help on what might be causing this is appreciated.
  • AndrewBird
    The Mad Scientist
    • 11898
    Have you checked the wiring between the MAF and the ECU? Do you have an aftermarket performance chip in the ECU?
