Click Click Click...Problem.
  • ///Mpressive
    • Mar 2006
    • 192
    So everything is hooked up for a dry fire and it will not crank. All I am getting is a click click sound. Sounds like it is coming from the starter. The battery is new and I tested the current.. it's good. WTF?
    Any Ideas guys? TIA
    08 Toyota FJ Cruiser, Rock Sliders, Mostly Stock for now, parts on the way....
    97 Toyota Land Cruiser FZJ-80, Front Bambi Basher w/ 2x100w PIAA's, mostly stock
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    check the battery isolation block, it was loose and i wasnt' getting enough voltage to the starter. and try cranking the engine by hand and see if it spins freely i too had that problem
    • 1990m3
      • 1180
      if all your connections are tight and you're still just getting the clicking then you might have a bad starter.
      This is of course assuming that your battery is strong and your wiring is correct.
      • Adrian_Visser
        • Jun 2006
        • 2823
        just give your starter a good wack with a rubber mallet, the solenoid might not be engaging all the way and theres nothing like a good bit of percussive maintenance to fix a sticky solenoid
        '89 Alpine S52 with goodies
        • ///Mpressive
          • Mar 2006
          • 192
          I re-mounted the block and gave the starter and solenoid a good whack. Still clicking. I'll grab another starter on Monday I guess and see what happens..
          Thanks for the help guys. Let me know if you guys have any other suggestions.
          'Ben
          • Garageaholic
            Freestyle Fabricator
            • Dec 2005
            • 5204
            Yeah, did you remember to wire up the starter directly to the battery?? I forgot that and all that happened was the 12v solenoid clicking...
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            Instagram.com/garageaholic
            Youtube.com/garageaholic
            • ///Mpressive
              • Mar 2006
              • 192
              What do you mean directly? This is how I have it..
              battery -> battery cable -> 12v iso block under hood-> starter cable to starter
              • matt
                • 3732
                The problem is that having the big power wire not hooked to the starter properly will give the same symptoms as a bad solenoid.
                I think we need to verify voltage at the starter solenoid before we tear into anything OR score a new starter. I suppose my girlish hands will come in handy for that on Sunday.
                • ///Mpressive
                  • Mar 2006
                  • 192
                  So yeah, she fired up today.
                  S52s are loud with only manifolds on.
                  • matt
                    • 3732
                    Flippin sweet.
                    PS. The only little snag we hit trying to start it was that the fuel pump relay had gone bad, so we had to swap it with one off another harness. Swaped that over and she fired right up.
                    • FredK
                      • 14762
                      Fire in the hole! Congrats on getting it to fire.
                      • tonytony
                        Knee deep in poopie
                        • Jan 2004
                        • 3498
                        so matt you helped out mpressive? it's sweet you got it to fire, i had the same problem with the fuel pump relay, but mine was grounding issues
                        • matt
                          • 3732
                          I had a little something to do with it.
