Euro S50B32 Q's
  • SpasticDwarf
    • Sep 2006
    • 1062
    Euro S50B32 Q's
    Hey all, I've got a 325is, and I am looking into an Euro S50B32 swap. Can anyone direct me to a place where i can get some info on required parts other than the engine itself?
    What electronics do I need?
    Extra parts?
    Any help is appreciated!
  • Ray Smoodiver
    • Jun 2004
    • 8809
    Domain name e30zone.co.uk (e30zone) is for sale at BuyDomainNames.co.uk
    Ask for Ian Haynes.
    /thread.
    • Skafrog
      • 1732
      you are in for a nightmare :)
      NASA MidSouth TT Director / GTS2 #018
      Mods: Coastal PS Fluid, 10w40 Oil
      Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
      • SpasticDwarf
        • Sep 2006
        • 1062
        Probably, but ive got my father backing me up on it. The story is basically that I told him I wanted to find a fresher m20 because mine is old, and then he wanted to look at all of the engine swap options, and is all for the s50.
        Hes swapped more engines and built more cars than anyone Ive ever met, so it wont be completely uncharted territory.
        But I do appreciate the warning. Ill inform the father.
        • Mot
          45 toting redneck
          • 4018
          maybe a built m50b32 (aka Us spec S50) would be a better choice, I know you would have alot easier time sourcing parts and if you build it right, you would be right at the same power level, minus the whole ITBS and euro factor.
          • Skafrog
            • 1732
            unless your dad has experience with EWSII, you guys got no idea :)
            • James Crivellone
              Head Janitor
              • 6305
              Exactly, EWS-II is a complete pain to work with, unless you wanna really butcher everything and do a complete harness swap with coded keys.
              If you want rare engines go S38B36/B38, or go the tried and true M50B32 method that everybody else does
              • morerevsm3
                • 108
                ummm, no you won't, the M50(S50US) heads don't flow anywhere near the same as euro, but US S50 + eurosport twinscrew would be great option
                12.921 @ 106.48mph - N/A E36 3.0L daily driver
                • SpasticDwarf
                  • Sep 2006
                  • 1062
                  Ahh, this is all very useful information. The only reason the euro s50 was chosen is becuase of the ITBs and power.
                  So are the m50b32 and the US s50 the same?
                  What method/engine is going to provide the most power output?
                  Thanks for all of the info guys.
                  • Brew
                    • 3060
                    The euro 3.2 is very similar to the s54. Dual vanos, solid lifters, 320+ hp stock. It would take a serious budget to get a US S50 to the same power levels while staying NA, and it would be close to a full-race motor.
                    I think the ideal setup would be a low-mileage, stock internals S52 with the Eurosport twinscrew kit and a 6-spd. Think e39 m5 power delivery in a package ~1000lbs lighter.
                    '91 318is
                    • ian332isport
                      • 124
                      EWS-II is a doddle to fit. No need for a complete harness swap :roll:
                      Ian.
                      • madjurgen
                        • May 2005
                        • 1203
                        it would take some serious rubber to get twinscrewed s52 power to the ground in an e30 but if you could youre looking at a 0-60 in the low 4s
                        As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                        You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                        • StereoInstaller1
                          GAS
                          • 22679
                          Ian, what the hell is a "doddle"?
                          Luke
                          Closing SOON!
                          Thanks for 10 years of fun!
                          • trent
                            Luke
                            I Think that means easy. I discussed this swap with Ian a while back, and he mentioned it wasn't hard at all. Just a matter of logically fitting EWS.
                            • ian332isport
                              • 124
                              Luke
                              Hi Luke,
                              Sorry, it's an English expression meaning something is very easy :up:
                              Cheers,
                              Ian.
