i noticed there's a bit of cranckshaft play in my m50 bottom end (the crank moves back and forth along its length), maybe a 1/10mm. also the rods play a little on the rod journals (is this a correct term?).
its odd because the cranckshaft is ok ( i measured a main journal and a rod journal and they were as round as they can be) and the engine was running fine. the main bearing shells were ok also.
i have no idea if this is ok or not (logically taken it cant be
