I'm in the middle of changing my head gasket and I can't get the head to come off. I counted the head bolts to make sure I had them all out, I removed the bolts holding it to the timing chain cover as well as the manifold and chain. But the head won't move at all, am I forgeting something? Do I just need a bigger hammer.
Head will not come off
Keep in mind the head weighs a fair amount. You might not even be lifting it enough to get it off.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
"I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
"If you've got a business, you didn't build that. Somebody else made that happen" Barack ObamaComment
The head gasket is probably stuck to the head and the block, preventing you from removing it. Try wedging a plastic putty knife in between the head and the block to see if you can get it free. I wouldn't use anything metal however as you could damage the mating surface of both the head and the block.Comment
Exactly what I was thinking, 2 or 3 on the front if I remember right, you will need a 1/4 drive torx E8 socket to get in there though
Right behind the chain guide.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
