oil level sender delete
  • BimmerToad
    • Sep 2004
    • 1537
    I'm currently doing an oil change and freshening up some gaskets and realized that I have the e34 oil level sender taking up space in my oil sump. My car doesn't have an idiot oil level light (318is), so I'm considering taking a cutting wheel to the sender and slightly increasing the capacity of the sump. Has anyone else done this? I'm concerned that I might create another leak by chopping off the sender.
    San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
  • trent
    god damnit todd, there is a factory plate that covers that. go buy it
    • trent
      plate - 11 13 1 726 357
      o ring - 12 61 1 277 129
      from e36 325i 94
      • LINUS
        • 2422
        I **think** it's as easy to swap overhead consoles as to cut that piece. At least if you left the sender wiring intact. Or get the blockoff plate that lets you run temp sender. Perfect location.
        Cutting that sender would only get you a 1/2 cup oil more - why bother?
        It's not how you handle the good times, but the faith you keep in the bad that defines you.
        • trent
          that sensor is for women in the first place that are not car people and don't know how to check oil
          • chucko
            • Mar 2004
            • 509
            My engine oil light came on the other day, turns out I was over a quart low on oil. Oops I guess I forgot to check it. :-)
            • joshh
              • Aug 2004
              • 6195
              It's good to have it there just in case. Specially if you track or autocross the car.
              "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
              ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
              • BimmerToad
                • Sep 2004
                • 1537
                as mentioned above, I don't have a full check panel.
                I guess I'll keep it in place until I can delete it the correct way.
                btw Trent: I had NO cam sensor gasket, and the hex bolt holding it in was finger tight! If that's my leak, I owe you beer for your troubles
                • BimmerToad
                  • Sep 2004
                  • 1537
                  I'll admit, that Turner piece is nice!
                  • LINUS
                    • 2422
                    I don't disagree at all. I just left it as I could use it and simply pop a few new holes in the pan, one to drive the factory M3 oil temp sender, and one for the VDO redundant in my center console. I just like to use all the factory stuff I incorperate, and add whatever else I like too.
                    You saw my skidplate based on your design, all I did was backweld some 1/2" alum where I wanted to run senders, pop a couple holes and thread it. Took 10 mins tops. I'll post a pic when my ghay Photobucket lets me.
                    But for those who pay for stuff to get welded, my approach would be a few bucks.
                    • trent
                      man on an S14 you have to check the oil a lot!!!!
                      • trent
                        you didn't have an can sensor o-ring at ALL????? I rule! hahaha
                        • trent
                          PLease. I check after every session. The oil light doesn't tell you if there is metal in your oil.
                          • KangamangusDriver
                            • Aug 2005
                            • 1870
                            I removed mine and fabbed up an aluminum cover plate to delete it
                            • e30_kid89
                              • Apr 2006
                              • 489
                              ^^^^but theres a factory one....why fab one up?
