M50 and S50 DME interchangeable
  • tjhartge
    • Jun 2004
    • 86
    does anyone know if the m50 413 dme can be swapped with the S50 413 dme?
    could i use the 413 dme from an M3 into my m50 system? has anyone done/tried this?
    i'm getting parts for my 2.9L upgrade and last bit would be the engine management system, and i don't think i'll go with AA chip as its abit over my budget too
  • trent
    yes they are the exact same.
    • tjhartge
      • Jun 2004
      • 86
      trent,
      does that mean that i can order an M3 tuned chip and use it in my m50 413 DME?
      i have heard that M3 chips will not work on m50 413 DME, although they are the same
      • trent
        a 413 dme is a 413 dme. I have used both 2.5 and 3.0L chips with no problems. Stock and aftermarket. I am using a red label.
        • JGood
          • Jan 2004
          • 7959
          What about m52/s52 interchangeability, both with each other and with s50/m50 units?
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • matt
            • 3731
            Whats the question?
            Nobody uses M52 or S52 ECUs in e30s.
            • trent
              yea you can't use those unless you do the full OBDII conversion
              • nefarious7907
                • Jan 2005
                • 1170
                So is there any benefit to the M3 chip? Ex: Higher redline, better fuel maps ect
                http://www.cardomain.com/ride/657387
                • matt
                  • 3731
                  Not if you have an M50.
                  • tjhartge
                    • Jun 2004
                    • 86
                    another thing would be EWS, does the 95+ M3 with 413 have EWS? or can i get the 413 chip for the M3 without EWS
                      • 37832
                      I bought a non EWS 413 DME from a M50 E34... Do I need to change the stock chip to an M3 one for my S50?
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • 325Projectz
                        • Jan 2005
                        • 1956
                        Quit acting like you're doing a motor swap. Go play in the the m20 kiddies area.
                        91 m3
                          • 37832
                          Argh! I am doing a motor swap damn it, I already have a motor.
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • matt
                            • 3731
                            Yes, Matt. You need a stock non-ews chip for an S50.
                              • 37832
                              Anybody 'round here have one to sell me?
                              Grover Beach, CA
                              www.BimmerHeads.com
