OK I was told by a source that the trans from the 318is and 325is (92-95) are basically the same and that either one will work behind the S52. These are the 250 Getrag units. I don't plan on having more than 280-290hp max from this engine and want to make sure I don't have to step up to the 320 ZF box from the M3 or 328is.
Also can I use the M3/328is 240mm diameter flywheel/clutch in the 250 trans?
