for those of you using the oil dipstick that came on the s50, what mark are you using to tell if the oil level is correct. I hear that it won't tell you the correct level for full, which is why people use the e34 m50 one. But I am going to use the s50 dip stick.
s50 oil dip stick
Tags: None
sorry i wasn't clear. I'm using the s50 dipstick and housing. I guess I may have to fork over another $30 for the e34 m50 dipstick housing since i have the correct dip stick, oh well.Comment
I got my pan from theeurodepot.com, it says it's supposed to come with a free oil pan gasket... didn't. So I went out and bought one. And didn't come with anything else. I took the oil pan baffle out of the new oil pan and left the s50 oil pan baffle in and put the oil pan on the motor.Stick and tube were included with my E34 pan. Who/where sold you yours?
I got mine from Joe, but he's cool about the ankle-biter stuff.Comment
Pick up the dipstick tube as well. The S50 one has fitment issues which may lead to a small oil leak.
Are the baffles designed to work with specific pans since the pickup points are in different locations (E34 v. E36)? I ask this because everyone seems to remove the baffle from the x50/52 engines instead of removing them from the pan.Comment
You beat me to it.
Hey Bimmer 335is, this motor is going in an E30 - correct? Just making sure. I don't think you can even get the pan close, since your oil pickup needs to change as well.
Here's how it goes. Unless you came up with a new solution, but I highly doubt that could happen.
1. Pull e36 pan. Throw in trashcan.
2. Pull e36 pan baffle. Same trashcan.
3. Pull oil pickup, careful as it's attached to the bearing cap. follow the oil trail to the trashcan. Add the oil pickup.
4. Retourque bearing cap.
5. install E34 pickup.
6 install new pan gasket
7. install new pan
8. tape over the dipstick hole until you are ready to install the E34 one.
You plan to secure your oilpump gear nut, right?
Here's mine:
It's not how you handle the good times, but the faith you keep in the bad that defines you.Comment
Okay, yes this is going in an e30.You beat me to it.
7. install new pan
Did change out my pickup tube.
1. pulled e36 pan
2. pulled e36 oil puckup, and cut the mount that is attached to bearing cap for clearance.
3. installed e34 pickup, and locktited the pump sprocket nut.
4. removed e36 oil pan baffle
5. tried to get oilpan to fit with e34 oil pan baffle
6. didn't work so I cut some of the oil pan baffle off for fitment on the side that was having trouble fitting.
7. still didn't work
8. put e36 oilpan baffle back in cuz I heard that others are using it
9. took out e34 oilpan baffle and installed with no problems
should I take the e36 baffle out and try harder to make the e34 baffle fit? I wasn't sure if this would be a huge issue or not.Comment
