You would have to drop the subframe to do it, wouldn't you?
Just break loose the bearing cap and take the piece off, it's not that much work.
I had to do some grinding on the E34 pan baffle to open up the little ' u ' shaped areas on the edges of the baffle. Not much, maybe 1/8". Small enough that I did it with a flapwheel, not a grinding disc.
