wiring. auto vs. 5speed?
    ok so i found a motor with 170,000kms from an automatic, i was wondering what do you have to do with the wiring harness or if anything at all?. also can i use the ecu that comes with it?. im getting the 5speed tranny with flywheel and it comes with a sachs stg.3 clutch. pretty much what im asking is can you use the wiring from the auto when i put the 5 speed on, because ive noticed on the 5 speeds there is that little connector on the passenger side of the transmission?.
    thanks
    -Mitch
    1988 e30 alpine white vert 5speed
    1987 e30 325 eta
    1983 e28 533
    2001 x5 4.4l
    1997 e36 M3 Alpine white 5speed
    1991 Jeep XJ I6 4.0
    EDIT: ahhh never mind I didn't see this was in the m50 swap forum... I was in e30/m20 land when I wrote that...
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
      Originally posted by JGood View Post
      What year/model are you talking about?
      5 Speed swaps are fairly well documented on here, you may want to do a search. You'll need a 5 speed drive shaft, pedal box, you'll need to do some basic wiring around the neutral start switch, etc...
      Your engine harness will work. A assume the connector you are talking about is the reverse light switch. You will plug it into the 5 speed switch.
      You don't usually need to change pedal boxes.
      The reverse light switch on the e36 is in the engine harness... you'll cut this off. You connect your e30 reverse light wiring to to the manual transmission's switch. There is also a connector for the auto on the e36 auto motor harness. Cut it off or let it hang. You can also cut off or leave the TCU connector on the harness.
        my e30 is allready manual, i just found a auto m50 in great condition. can i use the ecu from the auto,are they all the same.? the transmission im using is from the e36 cant i just plug the reverse light swith from the auto harness into the 5 speed tranny.?
        1987 e30 325 eta
        1983 e28 533
        2001 x5 4.4l
        1991 Jeep XJ I6 4.0
          anyone?
          1987 e30 325 eta
          1983 e28 533
          2001 x5 4.4l
          1991 Jeep XJ I6 4.0
            Yes you can use the auto ecu.
            You are going to hook up the reverse light switch exactly like it is now. You are not going to use the reverse light switch from the new motor harness.
