Trying to get the motor started... how low is low compression?
  • matt
    • 3732
    Interesting and pretty sucktastic. $300 for a used bottom end from Strictly german. I want a 2.8, but I kinda want to freshen my stuff too. Leakdown will be tested tomorrow night.
    • ///Mpressive
      • Mar 2006
      • 192
      Dude, have you still not confronted the seller of this motor? This is a GD nightmare for you..
      08 Toyota FJ Cruiser, Rock Sliders, Mostly Stock for now, parts on the way....
      97 Toyota Land Cruiser FZJ-80, Front Bambi Basher w/ 2x100w PIAA's, mostly stock
      • EtaSport
        • 2853
        How many miles on your m50? What was it like with the s50 cams? I would say its probably toast as we all know.
        I am thinking of going to 2.8 route as well since I am not to thrilled about the lack of low end torque that the 2.5 has. So the consensus is that we're almost better off picking up a 2.8 bottom end rather than building one? Granted the m52 in my dad's e39 has 175k on it and runs like a champ, but its got an auto and doesnt get driven quite as hard as my e30.
        Old and improved:
        • matt
          • 3732
          I wish I knew what it was like... it hasnt run since I put the M50 in.
          Ben- I will email him today.
          • FredK
            • 14764
            Hmm, this is quickly degenerating into the largest budget M50 swap in the history of man.
            Man a few months back someone was selling a low miles fully assembled S50 shortblock for $1000 on bimmerforums.
            I hope your luck turns around!
            • Rocla
              • 922
              Pour a little bit of motor oli into combustion chambers from sprkplug holes, as anyone can tell, this will not cure broken engine, but sometimes M5* series engines strangely lose compression and only way to get them running is to put a dash of oil into cylinders. Nothing to lose, give it a try.
              Current:
              BMW 320i 2d 2.0 m20 -88
              BMW 325i Cabriolet 2.5 m50 -88
              BMW 316i touring 1.6 m40 -90
              BMW 320i 4d 2,2 m54 -01
              • matt
                • 3732
                Done and done, still no start. I'm going to try a bit of ATF and a bit of MMO probably.
                I don't want to add up what I've spent on this car.
                And it's only going to get worse. But I do like the sound of a 2.8 turbo with S50 cams...
