Vehicle Speed Sensor
  • iflytii
    • Jun 2004
    • 482
    Does anyone know of an alternative source to tap into the vehicle speed sensor other than the green plug(s) on the back of the instrument cluster?
    I'm installing a Stack instrument cluster so using the stock cluster for the signal is no longer an option.
    Thanks!
  • browntown
    • Jun 2004
    • 3524
    The signal comes from the differential doesn't it? The sensor isn't part of the cluster is it? Should be able to tap the sensor wire from the diff.
    • iflytii
      • Jun 2004
      • 482
      That's what I was thinking. I think I identified the sensor wire into the cluster last night but between it being too late to start/drive the car (it's loud) and my multimeter battery dying, I couldn't verify it. I guess I was just looking for some reassurance that the raw signal would work without use of the cluster.
      • browntown
        • Jun 2004
        • 3524
        well i can't give you that assurance, I was just spitballing.
