Son of a BITCH!!!
  • Addissimo
    • Mar 2004
    • 1820
    definately make sure all of your grounds are good. Make sure the wires you think are power wires, are in deed power wires, and the wires you think are grounding wires, are indeed grounding wires. Also make sure that you have the thin grounding wire that goes up front to the cam covering plate (where the vanos unit is on 93+ engines) is connected.
    I'm guessing that your problem is ground/power related.
    -Addis
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
    • FredK
      • 14761
      His power wiring is messed up. He connected the starter power cable and DME ground correctly, but the other power wire is incorrectly hooked up to ground instead of hot. Mr. Swiss, I've replied in the comprehensive DOHC thread at the top of the page.
      • Addissimo
        • Mar 2004
        • 1820
        word...
        I've been there before.
        • Mr.SWISS
          • Nov 2005
          • 1251
          Well I am sure that was part of the problem but I still am not getting any fuel, fire I dunno didn't bother. The crank sensor gives 0 resistance on the outer pins and a little on the far and the middle. I will pick up my DME relay and CPS tomorrow. I hope it is not the DME. :(
          Originally posted by 325Projectz
          don't listen to the diagram... listen to mr. swiss.
          :nice:
          • Mr.SWISS
            • Nov 2005
            • 1251
            CPS and DME relay did nothing. I tested the relay plug and I don't think it is getting power. Thoughts?
            :nice:
            • FredK
              • 14761
              How did you hook up the power to the starter and alternator?
              • Mr.SWISS
                • Nov 2005
                • 1251
                Didn't, harness was already intact on the motor. It cranks fine.
                :nice:
                • mitch500
                  • Jan 2006
                  • 1092
                  fuel lines crossed?
                  1988 e30 alpine white vert 5speed
                  1987 e30 325 eta
                  1983 e28 533
                  2001 x5 4.4l
                  1997 e36 M3 Alpine white 5speed
                  1991 Jeep XJ I6 4.0
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    OMFG it started! I drove it around the block headers only and I have to admit, I pee'd a little nailing 3rd around the corner. It's at the muffler shop now, exhaust will be done at 10 or so manana. I will not admit the reason I didn't have power to my DME and fuel pump.
                    :nice:
                    • FredK
                      • 14761
                      Hahaha congrats!
                      • matt
                        • 3731
                        Your check engine light wasn't coming on... you could have saved yourself the cost of the CPS if you'd told us that.
                        • Mr.SWISS
                          • Nov 2005
                          • 1251
                          I know. But at least I can rest easy knowing that and the DME have been replaced so I won't get stranded due to either of those. In my defense the CPS looked OE.:mrgreen:
                          :nice:
                          • Bimmer335is
                            • Jun 2006
                            • 146
                            Please tell me, maybe I am having the same problem. I can't get mine to start.
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              I had an eyelet on the mounting point of the junction box istead of the part that actually has power. So I myself.
                              Just a few more loose ends to wrap up. My temp gauge just wiggles when I turn the key but never moves out of the blue(like the bottom of the blue) I hooked up the wires off of the adapter from the treehouse adapter for the oil level sender and just like they are labeled and the check light is still on. The washer fluid light popped on as soon as I filed it up. :loco: And I am getting some tranny noise after driving it all day( it may be a byproduct of the lightweight flywheel)
                              Oh, and I think I am gonna need a new diff, maybe S3.46. 4K rpm's at 60 mph isn't gonna work. Although it was nice to smoke that WS6 firebird earlier. :D
                              :nice:
                              • FredK
                                • 14761
                                Um, did he realize you guys were racing?
                                :mrgreen:
