Son of a BITCH!!!
  • Mr.SWISS
    • Nov 2005
    • 1251
    Son of a BITCH!!!
    No fuel, no fire, WTF?!?!?!?! :curse: :curse:
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
  • Erick
    Official R3V Drifter
    • 11169
    Ecu?
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • E30 Reaktionär
      Site Manager
      • 14451
      Originally posted by rwdrift
      Ecu?
      +1, maybe??? isn't new cars with computers fun to figure out what is wrong with them.
      1992 BMW 325iC
      1978 Chevrolet Monte Carlo
      • Mr.SWISS
        • Nov 2005
        • 1251
        Definitely a blast. Any ideas what these two plugs by the old ECU go to now that the old harness is gone?
        :nice:
        • PeaveyBassist
          • Sep 2004
          • 3511
          Crank position sensor. If the DME does not see a signal from the crank sensor, you wont have fuel or spark.
          Will
          RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
          Welcome e30 (brilliantrot '90 325is) 12/23/06
          DaveCN = Old Man
          My signature picture was taken by ME! Not by anyone else!
          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
          • matt
            • 3732
            If you lack fuel and spark totally, it's the CPS or the ECU.
            Is your check engine light coming on?
            • 1990m3
              • 1180
              Ews?
              • Mr.SWISS
                • Nov 2005
                • 1251
                It is always on when I turn the key, at least on the old engine. But I didn't pay attention to it this time. And this is a 92 M50 nv, it doesn't have EWS AFAIK.
                :nice:
                • Mr.SWISS
                  • Nov 2005
                  • 1251
                  Also forgot to mention . I pulled the connector off of one of the coils and put a test light to it. Going from left to right, the first pin in constant hot, nothing from 2 and 3.
                  :nice:
                  • matt
                    • 3732
                    The green wire to each coil is the trigger.
                    Your CEL can tell you a lot... figure out what it's doing and get back to us.
                    EWS should not be an issue.
                    • Mr.SWISS
                      • Nov 2005
                      • 1251
                      I went by the dealer and bought the DME relay, talked to a tech there and he said CPS as well, told me what it should read if it is good and t try that if the relay doesn't do it. I had already ordered a CPS just for good measure and the salvage that I bought the engine from garaunteed the engine to run, so they are soucing anonther 402 DME. I hope the relay works.
                      :nice:
                      • FredK
                        • 14762
                        What car was the donor? Was it an E34 or E36?
                        • Mr.SWISS
                          • Nov 2005
                          • 1251
                          e36
                          :nice:
                          • aeryk7
                            • Oct 2005
                            • 616
                            Check your grounds, lots of things need to be properly grounded.
                            Check these:
                            - DME Main Relay (5 pin)
                            - DMe properly grounded.
                            Is your fuel pump turning on ? if so . Then your not getting gas because something related at the harness.
                            253rwhp
                            My Vids(OLD)
                            http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
                            http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              Check these:
                              Pump never turns on.
                              :nice:
