M50 oil temp - oil pressure avg's
  • cahomey
    • Mar 2004
    • 1201
    What is normal oil temperature after fully warmed up? Mine is reading 185, 190. On a cold night on the freeway it's 150-160. Hasnt gone over 200 yet.
    My oil pressure on start up is 65
    My oil pressure on warm idle is 18-20
    In gear averages in the 40's - 60's
    Are these readings normal?
    w/ bone stock m50
    thanks
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
  • matt
    • 3732
    10psi per 1k RPM warm is a good rule of thumb. Your motor sounds fine.
    • FreedS4
      • 752
      Old thread revival, but I'd like to see what everyone else is seeing for average oil temps and pressures. Thanks!
      Chris
      • frankie591
        • Feb 2012
        • 545
        -Oil temp is ~150F measured at the drain plug
        -Oil pressure ~50psi start up, 15 psi idle once warm, ~60 psi at 7000rpm warm
        • FreedS4
          • 752
          Similar to the m20, which I guess should be expected.
          Chris
          • !kid
            • 1362
            (cold=100-150degF)
            59-60psi cold at idle
            60-65 psi cold under light load
            I am using 10w30
            :borg:
            • FreedS4
              • 752
              Anyone else have their average oil temps/pressures to post?
              Chris
              • ak-
                • 12422
                m20turbo
                75psi cold start up
                15psi warm idle
                70psi max load
                Temp doesn't go over 190 no matter how hard I beat on it.
                Does anyone know what temp does the thermostat for the oil cooler opens?
                I have an aftermarket cooler.
                1991 325iS turbo
                • FreedS4
                  • 752
                  Anyone else have their average m50/s50 oil temps/pressures to post?
                  Chris
                  • FreedS4
                    • 752
                    Bump for other oil temps/pressures from your m5x/s5x...thanks!
                    Chris
