I used this, but I called them to order and upgraded to a sprung hub disc to reduce chatter. I used the E36 trans though. Speed Solution International, Inc. 1350 W. Lambert Rd. #B Brea, CA 92821 Click here for a map Business Hours: 9AM - 6PM (PST) Mon~Sat Phone : (562) 905-3233, Fax : (562) 905-3238 e-mail: info@gripforce.com
Originally posted by 325Projectz
don't listen to the diagram... listen to mr. swiss.
I used an aluminum E30 325 flywheel with E30 M3 race pressure plate and disk. Works well for my 3liter as long as you don't mind a heavy pedal. E36 M3 aluminum flywheel and clutch work in the 260 as well.
i went with the m20 flywheel shaved down, and a "stage1" clutch and flywheel. my s50 isnt modded, so im not worried about being able to hold the power. if it doesnt work out, i will post up and tell every1 what NOT to use.
IG: @Baye30
