Alright e30m50 Questions.....
  • skatebline
    • Sep 2006
    • 167
    Lol ok i know its really bad but i have a few questions and it would be great! if some people could help me, i made up some pictures just cause it would be the easiest way of explaining this lol
    Thanks for the help.....if anyone does:)
  • So Live
    • 2512
    1 those go on the starter. They only fit on the pole they belong on.
    2 the black one looks like the big pole on the starter. i think the red one gets clipped.
    3 Determine whick one is power and which is ground. One goes to ground and one goes to the power dist. block with all those other wires. You can see what colors the wires are under the sheilding. Brown is ground and gets attched to the stock e30 spot on the shock tower (if its like mine) and the red wires goes to the power thing
    On second though, ditch all the e36 starter wires from the power block. Just run the e30 ones and save your self some trouble.
    Search around, im sure all these have been answered.
    Edit i mixed up the things. I used the wires with the m50 harness i had. I got rid of the e30 ones. Im sure someone said to ditch all those big sterter wires and just use the e30 one. Its not that big of a deal you just need a wire from the battery post thing to the starter.
    -Chris
    • Mr.SWISS
      • Nov 2005
      • 1251
      O shit I so want to tell you were you are screwing up right now as you are doing the same thing I did wrong. Something is wrong with pic #3. Get that ECU wire ran and cut you E30 grommet and you can use it on that harness. Peel back the black insulation and you will see what is what. Only 1 wire in pic 3 is a ground, You will figure this out soon. And when it won't start and you are not getting power to your DME and DME relay, check where you DME wires are hooked up and if they have power. ;)
      Originally posted by 325Projectz
      don't listen to the diagram... listen to mr. swiss.
      :nice:
      • skatebline
        • Sep 2006
        • 167
        lol sweet man thanks alot! i dont even know what your talking about at this time but i will figure it out lol,
        so i need to cut the ecu plug off?? :/
        • FredK
          • 14761
          No, you do not cut the ECU plug off. There is a grommet that plugs the hole in the firewall that in order to harvest, you have to cut it off the old E30 harness.
          • skatebline
            • Sep 2006
            • 167
            ohhhh alright i get it that rubber thing just to seal the hole??
            • FredK
              • 14761
              yup, the huge rubber thing.
              • skatebline
                • Sep 2006
                • 167
                The ECU plug doesnt even fit through the hole....
                • PiercedE30
                  • Apr 2005
                  • 4220
                  Make It!!
                  My 2.9L Build!
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    Are you super cereal? It is not even tight, mine slipped right through. And yes I meant cut the GROMMET off not ANY of your wiring. I didn't cut a damn thing and just hooked up the two big hot red cables together. Don't froget to pick up some larger washers to mount your ECU in the stock location.
                    :nice:
                    • skatebline
                      • Sep 2006
                      • 167
                      Alright ill get that done
                      Ok so if i get those power cables to the starter correct, ill be able to turn the engine over?...
                      Thanks
                      Jesse
                      • Mr.SWISS
                        • Nov 2005
                        • 1251
                        Thanks
                        Jesse
                        yes but it won't start.
                        :nice:
                        • skatebline
                          • Sep 2006
                          • 167
                          Alright sweet thats what i first wanna get done
                          Why wouldnt it start? what if i had the harness all hooked up and the maf?
                          • Mr.SWISS
                            • Nov 2005
                            • 1251
                            You are making a mistake in pic #3, I will tell you after you go through waht I did and I get to laugh and poke fun at you for at least 30 min to an hour. :p
                            :nice:
                            • skatebline
                              • Sep 2006
                              • 167
                              lol ok whatever
