No spark....WHY!!?
  • mazur
    • Jan 2006
    • 731
    No spark....WHY!!?
    I ran this engine several times before pulling it out of my wrecked e36. And for some reason, now I'm not getting spark.
    I verified this by taking out one of the coils and spark plug and saw if the spark plug was arcing while cranking.
    The chip I'm currently running (Stickley) w/ out EWS was sold after I pulled my motor, but was sent back because the buyer said his car wouldn't start with it. I remembered this, so I switched it with my stock chip (I cut pin 66 so EWS is disabled) and now my fuel pump doesn't work, and it still doesn't get spark.
    Any obvious ideas what it could be?
  • Jason89i
    • Sep 2004
    • 875
    see your original post from yesterday....trying to help.
    Originally posted by mazur
    IThe chip I'm currently running (Stickley) w/ out EWS ............................, so I switched it with my stock chip (I cut pin 66 so EWS is disabled) and now my fuel pump doesn't work, and it still doesn't get spark.
    so....which chip are you currently running?
    if you are running your stock chip w/ ews, no workie. if you have an ews delete chip with green wire (ecu pin66) cut, then you have other problems.
    jason
    • mazur
      • Jan 2006
      • 731
      jason
      So you're saying that it's not the Chip? Is is possible the ECU itself would be bad and still allow other functions to work?
      I borrowed some chips from my friend (all made for 506) and all they did was not let my fuel pump come on.
      • Jason89i
        • Sep 2004
        • 875
        So you're saying that it's not the Chip? .
        im not saying its anything yet. need some more information to help logically diagnose. speculation without information will lead you in circles.
        from the previous post that your fuel pump doesnt fire up.......
        Originally posted by jason89i
        need more info.
        what year is the car?
        in the "run" position, are you getting power out of the main relay? (large red/white wire.)
        in the "run" position, does everything inside the car work correctly?
        after 30sec, turn key to "run", do you hear the fuel pump working (or are you getting power to fuse 11? (fuel pump should power up, but only for a second.).
        from this post about not getting spark.......
        so....which chip are you currently running?.
        cheers, jason
        • mazur
          • Jan 2006
          • 731
          Quote:
          Originally Posted by jason89i
          need more info.
          I think I have this problem solved.
          I am currently running the Stickley, because that's the only one that allows the fuel pump relay to work properly.
          • DEV0 E30
            • Oct 2004
            • 8897
            Cutting this pretty close for bfest aren't you? :)
            All grounds hooked up?
            1 - From oil pan to chassis.
            2 - From one of the coils grounds out to nut near coils.
            3 - Shock tower.
            I think that's all of the ones I can think of that could have been overlooked.
            • Jason89i
              • Sep 2004
              • 875
              awesome. glad to hear the fuelpump is working properly. are you getting fuel pressure? (i only ask because ive swapped the lines a few times. )
              cheers, jason
              • mazur
                • Jan 2006
                • 731
                3 - Shock tower.
                Yes I got all those.
                I'm not going to bimmerfest because I can't get off work.
                cheers, jason
                Oh yah...fuel definately going the right way. I though that was my problem first, but found out I had it right the first time.
                • mazur
                  • Jan 2006
                  • 731
                  I switch CKPS and CMPS to see if somehow I mixed them up even though I labeled my wiring, nope it was correct.
                  I saw that the CKPS must be hall-effect since it's a 3-pin connector. Checked for voltage and got 4.8v, so no problem there. Ohmed out the sensor and got 580 and I believe that's fine as well.
                  Coil packs are getting voltage and ground.
                  If it's not the DME, I don't know what it could be:? So hopefully I can get someone to let me try out their known good DME with mine to verify. Or other way around and see if their car doesn't want to start.
                  • FredK
                    • 14762
                    Fuel rail ground? It's a little brown wire that hooks up to the engine lift eyelet at the front of the engine.
                    • IveGotIssues666
                      • Oct 2006
                      • 517
                      How are you bypassing EWS to start the car? I could have sworn EWS sends a signal to the DME to start the car (It's like that in the E46's at least), does your aftermarket chip take care of this?
                      What happens with your stock chip in and EWS pin 66 connected instead of disconnected? Anything?
                      Jared
                      • matt
                        • 3732
                        Jared
                        No... the DME has nothing to do with starting the car.
                        The key signals the starter.
                        • mazur
                          • Jan 2006
                          • 731
                          Jared
                          Havn't tried that, but might just in case the chip took a shit.
                          • Lobstrosity
                            • Aug 2004
                            • 116
                            Sounds like the chip is messed up. If the guy who bought the chip tried it out and couldn't start with it, and now you can't either, maybe it got fried in transit, or the buyer fried it while trying it out.
                            • mazur
                              • Jan 2006
                              • 731
                              He was also trying to use it on his 506 DME, which I figured was possibly the reason it didn't work.
                              I'm not sure what to do now. I think I'm just going to change my CKPS and see if that fixes it. If not I'll get a new chip.
