Need information on M50 swap
  • blackmamba1
    • Jan 2007
    • 99
    I am in the process of planning on my m50 swap... I have a 1985 318i.
    What do I need/ need to do?
    I am assuming that it is not a straight forward as a M20 - M50 swap.
  • smonkbmw
    Professor
    • Jun 2006
    • 4549
    you need to search is what you need to do.
    yes it is as straight forward as a m20-m50 swap.
    look in the 24valve section
    • FredK
      • 14763
      Come on dude, you gotta really try harder than that. That's like coming on the general technical forum and saying, Timing Belt. How do I change it?
      Anyway, it is pretty much just as straightforward, except the wiring will be different.
      • matt
        • 3732
        You will also need a new radiator, driveshaft, transmission, clutch, clutch slave cylinder, flywheel... and a lot of other stuff.
        • Court M3
          • Jan 2004
          • 6713
          or http://www.r3vlimited.com/board/showthread.php?t=45442
          Continuous For Sale Thread
          323i s50
          • StereoInstaller1
            GAS
            • 22679
            First and foremost, you will need to upgrade your rear brakes.
            M50+drums=R3Vd E30
            Unless you wear manties.
            Closing SOON!
            Thanks for 10 years of fun!
            • backtrail69
              • Jul 2005
              • 4471
              Buy a 325 chassis...4 wheel disks and bigger struts FTW! Everything is easier..
              :: PNW Crew ::
              '87 325 4dr, '74 2002
