318is => e36 m50 wiring
  • FredK
    • 14763
    That guy's chart is the same one that's been floating around on the internet for a while now. If you use his diagram the ABS won't work.
    • So Live
      • 2512
      Well thats good to know.
      -Chris
      • ard
        • Nov 2007
        • 3
        Originally posted by asubimmer
        Also my engine was off an auto e36 and the harness has two plugs like the dme. One is for the dme but what is the other for?
        sorry for old thread renewal, but did You find how to by pass the DME thinking that the transmission is always in park or neutral?
        Arnas.
        • asubimmer
          • 6482
          Arnas.
          the auto and manual DME's are the same
          • FredK
            • 14763
            the DMEs are the same but automatic cars have a relay that will disable the ignition unless it is in park.
            • asubimmer
              • 6482
              weird I didn't have any probs w/ that?
              • asubimmer
                • 6482
                btw how do you make it work? lol
                • ard
                  • Nov 2007
                  • 3
                  strange.. i was told that there is no way i can start my engine without fooled dme about park/neutral gear.
                  another strange thing is that my wipers shake a little bit (just moves a little) when i turn key to pos1 (pos0 inserted, pos1 turned, pos2 ign, pos3 ign+starter)
                  could it be missed ground somewhere?
                  • FredK
                    • 14763
                    if you have a manual car, you won't have any problems with it.
                    You are correct. You need to fool the car into thinking it is in neutral and park. That is what the second part of Mike's post says.
                    • 318isbmw
                      • Nov 2005
                      • 2843
                      So has anyone used the pin setup which was posted on page one of this, and does it work. About to setup my car this friday and was wanting to know if its one I should consider going off of or not.
                      Thanks,
                      Brendan
