Engine won't turn over, VANOS stuck?
  • gotKRAUT
    • Apr 2007
    • 136
    sure its nothing to do with the cam install?
    Kyle Sutherland
    1995 BMW 540i/6:
    The Calypso Beast Vid 0-70ish
    1987 BMW 325es: Face & Butt Lifted/M50tu Swapped*Sold*
    1985 VW Scirocco: Too many mods, money pit*Sold*
    • Jason89i
      • Sep 2004
      • 875
      do you have aftermarket cams? the schrick cams (and of course sunbelts) should be dialed in after install. installing them "straight up" with the cam block per bentley can cause piston/valve contact. cheers, jason
      • Bmjpv
        • Mar 2007
        • 561
        The cam installation looks and can be easy to setup ,but misalignment can be made. If you have done a fair amount of these setups it's easy. But the first time or two misalignments can be made.Back to basics, TDC and recheck! Jason can you expand on the diaing in of aftermarket cams and the plus that we all might get by doing so. thanks joe
        • aeryk7
          • Oct 2005
          • 616
          The engine would start whether the VANOS was stuck timed wrong , not plugged in, whatever. If your engine only turns by hand 20 degrees then your flywheel is touching the bell housing , the engine is timed wrong and the valves are touching the pistons or something like this. Vanos is actuated by oil pressure up into the rpm range your car is obviously not starting so you wouldnt even know if your VANOS is stuck.
          253rwhp
          My Vids(OLD)
          http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
          http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
          • Mr.SWISS
            • Nov 2005
            • 1251
            If it is in gear I am going to lmao rofl.
            Originally posted by 325Projectz
            don't listen to the diagram... listen to mr. swiss.
            :nice:
            • Bmjpv
              • Mar 2007
              • 561
              Just so everyone is clear how this VANOS works,It's electicly engadged by the solenoid, oil pressure is to the VANOS is constant .ECU programing signals power to the VANOS solenoid at preprogramed RPM ,adusting timing and away you go. joe
              • matt
                • 3732
                Originally posted by Bmjpv
                Just so everyone is clear how this VANOS works,It's electiclly by the solenoid, oil pressure is to the VANOS is constant .ECU programing signals power to the VANOS solenoid at preprogramed RPM ,adusting timing and away you go. joe
                Vanos activation depends on RPM, load (TPS, MAF), coolant temp... there are a lot of factors. The Vanos solenoid controls a two way valve so that if it's powered, the plunger is being held in the advanced position and if it isn't, the pressure is holding it in the retarded position.
                I really cannot see any way a vanos could possibly lock up a motor.
                • Jason89i
                  • Sep 2004
                  • 875
                  The cam installation looks and can be easy to setup ,but misalignment can be made. ......Jason can you expand on the diaing in of aftermarket cams and the plus that we all might get by doing so. thanks joe
                  post from last year. http://forums.bimmerforums.com/forum...hlight=schrick
                  jason
                  • triggrhaapi
                    • Feb 2007
                    • 350
                    I have taken everything timing related off, VANOS unit, tensioners, gears, you name it. It's 100% guaranteed not related to anything in the engine itself. I removed the spark plugs to see where the pistons were in relation to the valves, no chance of contact whatsoever.
                    I'm thinking that it's either that my starter is broken and jammed or something else is somehow jamming the flywheel preventing it from moving.
                    1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
                    • Jason89i
                      • Sep 2004
                      • 875
                      Originally posted by triggrhaapi
                      I have taken everything timing related off, VANOS unit, tensioners, gears, you name it. ........
                      just a side note.....i know you already know this but.....Do not try to spin the crank by hand without the timing chain hooked up with the cams. if cams dont move, then piston will contact open valve. cheers, jason
                      • Bmjpv
                        • Mar 2007
                        • 561
                        Now I'm really interested in this, at this point I'd lift the cams out (valves will close ) and roll the engine over by hand. The chains won't matter at this point. Keep us informed. good luck joe
                        • matt
                          • 3732
                          +1
                          If you can take the cams out and the crank spins, you timed the cams wrong.
                          • Lobstrosity
                            • Aug 2004
                            • 116
                            Did you remove the a/c pulley from the engine? I did this, and but then the bolts were too long for just the crank pulley/harmonic balancer, and it would only rotate a little ways before getting jammed into the block.
                            • matt
                              • 3732
                              Ohhh... thats a good one too. Had the same thing happen but I caught it while it was still on a stand.
                              • triggrhaapi
                                • Feb 2007
                                • 350
                                Hmm that very well may be it then. I did remove the A/C pulley... I bet that's it.
