dumb question M52 engine
  • DTRguy
    • Jan 2007
    • 118
    So I am putting together an M52/50 hybrid together and I was wondering (since I can't remember); what kind of water neck or attachment is there on the outlet of the waterpump on the m52 block. My M50 has a aluminum neck. And yes I could swap it all over... but would rather not. The neck on the m50 is smaller in dia. so that won't work either. Just wondering what is there factory. Thanks!
  • matt
    • 3732
    It's empty. That's why AA sells a pipe you can pound in there so you can hook up the early spider hose.
    • DTRguy
      • Jan 2007
      • 118
      Excellent! That's what I wanted to know! Now, who is AA? Thanks Matt!
      • matt
        • 3732
        active autowerke
        • Dave
          E30 RAT
          • 11675
          And Kevin, don't forget to get the Stewart water pump. Bimmerworld has those.
          Current Cars
          2014 M235i
          2009 R56 Cooper S
          1998 M3
          1997 M3
          • BigD
            • Jul 2006
            • 1085
            • DTRguy
              • Jan 2007
              • 118
              I pulled the WP out and it is the upgraded metal unit. So I should be good there. Thanks guys for the help and the linky... Much appreciated. Another good resource I need to add to my favorites list right Dave! ;)
              • Dave
                E30 RAT
                • 11675
                Yeah, well the metal impeller ones have faults as well - I don;t recall the specifics, but BMW actually shit-canned those after a while and went back to plastic. Mike Miller (Tech Talk guy in Roundel - also does the same column for Bimmer) can explain it - I can't.
                The Stewart Products one is supposed to be light years better, especially in an engine that will see some serious use.
                But you are just putting this in a daily driver for some little old lady, right? :giggle:
                Current Cars
                2014 M235i
                2009 R56 Cooper S
                1998 M3
                1997 M3
                • DTRguy
                  • Jan 2007
                  • 118
                  Well, umm yeah.... that's what it's for:twisted:
                  • matt
                    • 3732
                    BMW uses composite water pump impellers now.
                    • DTRguy
                      • Jan 2007
                      • 118
                      so then is there particularily anything wrong with the metal (welded sheetmetal type? I have apparently two of them.
                      • matt
                        • 3732
                        They had bearing issues, I think. BMW switches suppliers for no reason sometimes though. There might be nothing wrong with either of them.
                        Keep in mind, these cars need waterpumps almost like M20s need timing belts...
                        • DTRguy
                          • Jan 2007
                          • 118
                          Interesting... Learning more and more. Never heard about this until today... Yesterday I learned about the Oil pump nut fix issue I have to work on! More to buy more to buy!
