Should I get OBD1 or OBD2 down pipes? I will make my own exhaust, but time budget keeps me from making my own down pipes...
					What downpipes are you using? I'm using OBD2 headers on an M52...
 i used all obd 1 stuff but the down pipes shouldnt be that much different. The only difference in size is in the o.d not i.d. so they dont flow any better than the obd 1 stuff but like static said they should be quieter and hold heat better.
 i made 4 welds per pipe going inbetween the manifolds and the stock e30 cat section. I have plenty of clearance for everything. At least 1/2 inch in all spots.
 I think for my nv m50 motor it was the best/easiest/cheapest way to go. I dont think the e30 exhaust is holding it back. Ill upgrade the exhaust when theres a turbine infront of it.-ChrisComment
 I have the obd2 ones but one the front one wants to hit the sway bar so I may have to put some washers or something under the ps motor mount to raise it up a tad so it can fit. Thats a common prob right?///Alpinweiß II 24v 91' 318is, Alpinweiß III 99' 323i, 04' Yamaha R6 SE for sale, 00' VW GTi, 83' El Camino BURNED, 01' P71sold, 92' Miatasold
