vanos units? and OBD2 questions.
  • e30devo
    • Aug 2005
    • 1102
    i searched so dont say it.
    i was wondering if the vanos units on different motors are all the same? like would a m50 vanos unit fit an s52? or whats the deal?
    also, in detail.. what is needed to swap to obd1 on an s52. parts wise and any other tips or tricks.. yada yada. thanks in advance.
    -Devin
  • matt
    • 3731
    All vanos units are the same, but the solenoids are different. OBDII solenoids have a shorter lead.
    The OBDII conversion has been covered, in detail, many times. Search and you will find it. (On bimmerforums.)
    • equate975
      • Jun 2004
      • 3382
      Yeah, but you can just extend the leads on the OBDII solenoid and it works. :)
      Thats what I did.
      Rollin' with a Geistkuchen
      • e30devo
        • Aug 2005
        • 1102
        thanks for the info. bimmerforums had everything matt. ty.
        • e30devo
          • Aug 2005
          • 1102
          from the dead.. matt, you say the obdII is shorter.. if im using a vanos unit from obdI itll still work correctly on s52?
          • e30s52
            • Oct 2007
            • 5235
            /\ yes
            www.gutenparts.com
            • hoveringuy
              • Dec 2005
              • 2715
              I've looked at the OBD1 and OBD2 solenoids closely. They are functionally identical except for the wiring. Interchange them as much as you want.
              • e30devo
                • Aug 2005
                • 1102
                cool. thanks guys. so helpful. im sure these wont be the last of my questions.
