I have two dmes, Silver lable w/o ews and one is a 413 red labal. I am getting two different problems w/ each ecu.
413 red labal
W/ the red labal, I am not getting the switch ground from the dme to the main relay. If I ground out the brown wire, the relay clicks and the car starts.
Silver w/o ews
My injectors are not firing, I am getting power from the main relay, but no pulse ground to the injectors and no ground to the fuel pump relay. My fuel pump works. I grounded out the injectors one at a time to see if they spray and they do. I then tried to start the car and it fired right up, until the fuel burned off.
What do you guys think? Which ecu should I use?
Thanks Guys
413 red labal
Silver w/o ews
Thanks Guys
