Oil level sender light
  • BeirBrennerE30
    • 2740
    I have decided that i really dont need that oil level idiot light so I am going to be replacing it with an oil temp sensor.
    But i dont want that retarded light to stay on. How should i get it to turn off? would grounding bot the wires do it?
    Also how waffleswaffleswaffles sthat light know when to turn on? Say if i wanted to use it for another kind of warning light what signal would each wire need to turn on the light?
    thanks
    e30sport.net
    '06 M3 Competition - 6-speed
    '97 Range Rover Vitesse
  • BeirBrennerE30
    • 2740
    anyone???
    e30sport.net
    • backtrail69
      • Jul 2005
      • 4471
      Replace the drain plug like everyone else and keep it. It has saved me before.. It comes on when you are a quart low.
      :: PNW Crew ::
      '87 325 4dr, '74 2002
      • So Live
        • 2512
        Mine still dosnt work :(
        -Chris
        • Mr.SWISS
          • Nov 2005
          • 1251
          Ok ya lost me chief.
          WTF does the drain plug have to do with it?
          *Waiting for supper scientific answer*
          Originally posted by 325Projectz
          don't listen to the diagram... listen to mr. swiss.
          :nice:
          • PiercedE30
            • Apr 2005
            • 4220
            well the drain plug does keep it in the pan..........??
            My 2.9L Build!
            • backtrail69
              • Jul 2005
              • 4471
              It looks something like this:
              It replaces your drain plug with a oil temp sender. I have been running one just like this in my turbo car for over a year. Bav Auto and Parker Performance sells them for BMWs.
              :: PNW Crew ::
              • BeirBrennerE30
                • 2740
                welll the point is that i dont want the sender.... dont need the sender. That spot can be used for better things... i just want to know how to turn the light on and off...
                e30sport.net
                • Mike B.
                  • Jan 2006
                  • 987
                  What better things? Wiring up the idiot light is simple (it is then useable and it goes off), and you can use the temp drain plug for your other requirement.
                  It's always better to have more information...
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    Ok so WTF is this thread about? I thought it was the oil LEVEL sender and getting the light on the CHECK PANEL off, how the fuck did you guys get on oil temp senders that would need a separate gauge?
                    :nice:
                    • BeirBrennerE30
                      • 2740
                      i dont care if you THINK i should have that sensor.... i dont want it... how do i turn the damn light off!!!
                      e30sport.net
                      • e30devo
                        • Aug 2005
                        • 1102
                        if r3v says you need one.. then you need one. heres an idea.. you could pull the bulb..
                        • TwoJ's
                          • Oct 2005
                          • 4908
                          2nd most retarded thread on r3v this year.
                          The reason why backtrail suggested that is because the OP said he wanted an oil temp gauge and he was going to remove teh oil level sender. The obvious better solution is the drain plug.
                          Now, the OP is too cool for school and doens't want to keep the idiot light.
                          • BeirBrennerE30
                            • 2740
                            this thred officially sucks....
                            e30sport.net
                            • Kruzen
                              • Mar 2004
                              • 5603
                              A thread is only as good as its poster.
                              Who doesn't love a little BBQ?
                              Griot's Garage at a Deep Discount
