Oil level sender light
  • FredK
    • 14762
    The E30 oil level check control is governed by 3 pins.
    Pin 1: Static
    Pin 2: Dynamic
    Pin 3: Gnd
    On the C101,
    Pin 2: Static oil level (resets oil light)
    Pin 10: Dynamic oil level (triggers oil light)
    On the 525i oil level sensor:
    Pin 1: Dynamic
    Pin 2: Gnd
    Pin 3: Static
    To defeat the oil light just take the resistance of the oil level sensor pin 1 to ground, and use a resistor of that same value to ground.
    I'm not sure how you can trigger the E30 light because it's not just a simple on/off switch; I guess it uses a mechanically coupled switch, when one goes off the other goes on. I don't have much electrical knowledge, but I'm sure someone could help you out.
    • BeirBrennerE30
      • 2740
      Thank you fredk for an actual answer...
      e30sport.net
      '06 M3 Competition - 6-speed
      '97 Range Rover Vitesse
