Car starts - runs fine for 10 seconds - then runs like SHIT!
  • RyanZ06
    • Apr 2007
    • 226
    Here is the situation.
    I have a M52 converted to OBD1. 413 red label, walbro 255lph fuel pump, other wise stock.
    I am using a tree house adapter.
    If i reset the ecu (leave the battery disconnected for a bit) the car will start, and run like normal for about 10-20 seconds, and then it just hits a wall. The car instantly starts dropping cylinders, and eventually dies, and will not restart (fouling the plugs).
    I have no access to a code reader locally (i've been searching for one)... but I have treid to do as much diagnostic as possible...I cannot figure it out!
    Does anyone have any ideas?
  • FredK
    • 14762
    Crap, sounds frustrating!
    What have you done in terms of diagnostics?
    • RyanZ06
      • Apr 2007
      • 226
      Checked grounds, replaced o2, replaced coolant temp sensor, changed plugs, changed fuel filter...
      the car has a brand new Cam/Crank angle sensor, brand new knock sensors, a new vanos unit, new water temp sensor...
      The only thing left to try is a MAF sensor, and a IAT sensor.
      • trent
        you don't need a code, reader, do the pedal trick and tell us the codes
        I have seen ECU's do simliar
        TTT
        • e30polak
          • 6136
          check ur hfm...maybe fuel pressure regulator? coil packs...
          INSTAGRAM: @UNDR8D_EMPIRE
          • Bmjpv
            • Mar 2007
            • 561
            basics
            Consider too much fuel? too much pressure because of a bad pressure regulator, Water temp sensor correct type or tunning too rich after cold starting?? Replace main fuel pump with OE to go back to basics. joe
            • PiercedE30
              • Apr 2005
              • 4220
              sounds like its air flow related. i've seen a few cars at the shop that ran like shit until we plugged a different hfm in.
              My 2.9L Build!
              • matt
                • 3732
                Definitely sounds MAF.
                I swapped MAFs to a good one tonight (old one was sucky), and the car did exactly this. Then I reset the ECU and it was all good.
                • Van Westervelt
                  • 9365
                  TTT
                  What is this pedal trick? I have heard of it two times now. And how do you get the codes that way? I have a reader, but I am curious about this too.
                  • mazur
                    • Jan 2006
                    • 731
                    Just unluggin the HFM should help the car run better. It might be a little worse the first time you try to run it this way, but should run pretty well soon after....that is, if your HFM is currently crappy.
                    • RyanZ06
                      • Apr 2007
                      • 226
                      I'll replace the plugs again tonight (they are fouled out again).. and try running it again without the MAF.
                      I wont swap back to the stock pump, because the stock pump is garbage, and it broke.
                      I will check the FPR, but how does such a simple mechanical device go bad? That doesnt explain the perfect start up , and then eventually/progressively dropping cylinders.
                      • trent
                        search!
                        TTT
                        • RyanZ06
                          • Apr 2007
                          • 226
                          no more guesses?
                          • Bmjpv
                            • Mar 2007
                            • 561
                            guesses
                            not just gresses but educated guesses! What is fuel pressure? temp sensor (not sender)values and correct? Air mass meter do go bad but generaly don't go to full rich and flood out plugs. Don't look for the one in a million problem, it's all in the basics, don't loose that approch . joe
                            • aeryk7
                              • Oct 2005
                              • 616
                              Sometimes a leaky valve cover will be the culprit of this, oil will get into the spark plug tunnels and when the car gets hot it will make the car misfire.
                              253rwhp
                              My Vids(OLD)
                              http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
                              http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
