E39 528i oil pan- can it be used?
  • Rigmaster
    • 3464
    I've got a line on a pretty cheap M52 from an E39 528i, seller says it has a blown head gasket, but it's complete with all accessories, including oil pan.
    I know the common pan to use for the E30 24v swap is the E34 M50 pan- just wondering if anyone has used the E39 M52 pan?
    Bret.
  • FredK
    • 14763
    Correct me if I'm wrong, but doesn't the E39 M52 have a rear oil sump?
    • matt
      • 3732
      That is the question.
      Bret, can you post a pic?
      • Rigmaster
        • 3464
        I can if and when I get this engine. ;)
        Was just trying to figure out if I could easily cover my costs on this deal..... I figured if the oil pan could be used on the E30 24v swap it would be common knowledge by now.
        I'll post up some pics if I get it- should know in the next day or two.
        EDIT: per realoem diagrams, it does look like the E39 528i is a rear sump oil pan.......ahh, well.....
        Bret
        • FredK
          • 14763
          Lookin around on fleabay for 528i M52s, it looks like it's a rear sump.
