using an m52 and e36 trans can i use the m20 single mass flywheel and normal sachs clutch?
e36 flywheel options
taht sort of clears it up...
does the e36 starter work with the e30 flywheel, now? -
only if you swap the drive gear over.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
and don't forget the clutch slave cylinder
you'll havta use the cylinder from the m20 single mass setupComment
