Windage tray? Which to use...
  • PiercedE30
    • Apr 2005
    • 4220
    It would be inside the pan on the bottom.
    My 2.9L Build!
    • LINUS
      • 2422
      Kinda what I thought. So hopefully it will be quite some time until I know when mine was made.
      It's not how you handle the good times, but the faith you keep in the bad that defines you.
      • Mr.SWISS
        • Nov 2005
        • 1251
        Originally posted by LINUS
        Sorry man - I got a pan from that big wrecker in NorCal, didn't state what year it was off on my receipt, just that it was a 535i, and the car # in the wrecking lot, IIRC.
        If they put that circular production code on the pan, someone tell me where it is and I'll look - pan's on the block already, so if it's inside I can't get at it.
        Well no wonder. :p
        Originally posted by 325Projectz
        don't listen to the diagram... listen to mr. swiss.
        :nice:
        • matt
          • 3732
          Mine was made in '04. :pimp:
          • LINUS
            • 2422
            Originally posted by Mr.SWISS
            Well no wonder. :p
            You got me.... My Bad. I meant 525i, and this wasn't the place to make a typo, so good catch.
            I'll go back through my receipts in the next couple days. My pan came from Bav Auto, so they are pretty good about tracking what car a part came from.
            • BigD
              • Jul 2006
              • 1085
              Here's my thread on the exact same problem. You'll see in the first post, how the 2 different types of pans compare. Look closely at the depth of the cutouts, the non-grinder design doesn't even have the flap at the front due to the depth of the cutouts.
              FWIW, mine was from a 92 525i. I'd guess most people got theirs from a newer, Vanos car.
              Also FWIW, it seems some people just cut the E34 windage tray out and leave the E36 one in.
              • LINUS
                • 2422
                I thought about that as a solution, but it just seemed like the windage tray is more than likely engineered to go with which direction the sump is (fore or aft), and the results might have little effect, but it just didn't seem right to hybridize the pan/tray combo.
                It seemed to me like the e34 pan tray was 'steering' the oil to the sump, but the e36 one didn't look to me like it was trying to direct the oil in any direction, at least that's what I saw when I was sizing this all up.
                Does anybody have good evidence that what I'm thinking doesn't hold true?
                • BigD
                  • Jul 2006
                  • 1085
                  That's what I thought as well... they made the E34 design at the same time as the E36, if one was better than the other for both applications, they would have been used - it's cheaper if nothing else.
                  • golde30
                    • 11464
                    yeah i remember this thread. i wasnt having the same problem as you, i just wanted to know which tray is better to use. and apparently, its the obvious one! hehe
                    IG: @Baye30
