cylinder head bolt torque
  • 02stu
    • Jan 2005
    • 872
    Quick question, what is the proper torque for m50 or s50 cylinder head bolts.
    Thanks
    Stu
  • ZiMMie
    • Jun 2004
    • 968
    86Inch Lbs. 10N.m
    for both small and the main bolts
    www.stancefactory.com
    • PiercedE30
      • Apr 2005
      • 4220
      I thought the main bolts where 17 ft lbs plus 50 degrees.....
      My 2.9L Build!
      • ZiMMie
        • Jun 2004
        • 968
        • PiercedE30
          • Apr 2005
          • 4220
          hey, you have Mitchell On-Demand lol. so do I (at work).
          My 2.9L Build!
          • ZiMMie
            • Jun 2004
            • 968
            any there is internet i got mitchell there also :)
            • 02stu
              • Jan 2005
              • 872
              Dam, I torqued mine to 30Nm. I used this site which looks legit. http://tedserbinski.com/files/bmw_torq.pdf
              Now the car is acting like it has a blown head gasket, so I guess that is why.
              • PiercedE30
                • Apr 2005
                • 4220
                30 NM is 22 ft-lbs. Did you do the additional 90 degrees of torque and then another 90 degrees after the initial torquing of 22 ft-lbs/30Nm?
                My 2.9L Build!
                • matt
                  • 3732
                  That site is legit, it says right under 30Nm that you need to do two 90* torque angles after that.
                  Doh.
                  Hey don't feel bad, I made a bigger mistake than that with mine...
                  • 02stu
                    • Jan 2005
                    • 872
                    No just 22 ft-lbs/30Nm.
                    • PiercedE30
                      • Apr 2005
                      • 4220
                      well that would be the problem right there.
                      My 2.9L Build!
                      • 02stu
                        • Jan 2005
                        • 872
                        wait, if I followed the site and added an addition 90 degree torque angle I would have over torqued it even more
                        • PiercedE30
                          • Apr 2005
                          • 4220
                          That's the idea. You torque it initially to 22 ftlbs. Then, you torque it down another 90 degrees (all bolts), then once you do that sequence, you do an additional 90 degrees in the same sequence.
                          My 2.9L Build!
                          • 02stu
                            • Jan 2005
                            • 872
                            So the information on that site is correct? Can add the torque angle now? or should I replace the bolts and gasket.
                            Thanks again for you help!
                            Stu
                            • PiercedE30
                              • Apr 2005
                              • 4220
                              Go ahead and do the torque angle, both of them. Do one sequence, then let it sit for about 10-15 minutes before doing the next sequence. That should let it get to where it needs to be. If the HG still leaks, then pull it off and put some studs in there with a new gasket.
                              My 2.9L Build!
