M50 swap, the getrag sits funny, I know there was a template going around to make the right crossmember. Does anyone have it or have an alternate solution?
Getrag Cross Member
Tags: None
give him a break twig. Although its great to search its not like this topic has been beat to death like a lot of other topics. I assume you are talking about using the m20/getrag 260 with the m50. There was someone selling modded brackets not too long ago. But I would suggest to either go with the m42 or m50 tranny. The getrag 260 has to sit at and angle to fit the m50, which isn't really the best thing to do. Sure it works but cutting corners doesn't help you in the end. The tranny from a m42 can deff handle the power as they are rated at 240lbs of tq but if you are worried then you can just use the tranny from any x50/2.///Alpinweiß II 24v 91' 318is, Alpinweiß III 99' 323i, 04' Yamaha R6 SE for sale, 00' VW GTi, 83' El Camino BURNED, 01' P71sold, 92' Miatasold
Im almost at the end of my budget and I would liek to use the getrag, also im not abotu to click threw 50 something pages to find something, then once i find it lose it, if anyone can send me the template or point me in the direction of someone with the brackets it would be much appreicated.Comment
There's no template. Just cut the cross member so that you take out/remove 10* from each side of the mount.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
I know there's another more detailed thread floating around too...Comment
Is there a differance in the early model e30s? because my cross member needs to be higher on the passenger side by abotu 3 inches.
The way it sits now, driverside liens up with bolt, passenger side hangs about 2.5-3 inches from chassisComment
