Clutch kit for a m50 powered e30
  • thuibers
    • Jan 2005
    • 44
    Can anyone suggest a good clutch kit for my 1993 3.0 m50 with the e36 trans
  • kylebes1
    • May 2004
    • 2804
    Did it start life as a 2.5 and you rebuilt it?
    <300 hp non m3 e30 single mass flywheel with non m3 e30 or e36 (e36 is a little lighter) clutch. e30 flywheel requires e30 clutch slave.
    >300 hp e36 m3 clutch and flywheel. Larger diameter pressure surface.
    • matt
      • 3732
      Horsepower has nothing to do with clutch sizing. It's all about torque. If you're even coming close to 200ftlbs, I would not use a 228mm clutch.
      I would not use any 325i (e30 or e36) clutch/flywheeel with anything besides a stockish 2.5l.
      There is a good reason BMW equipped all the other S50/M52/S52 with a 240mm clutch and flywheel.
      • Mr.SWISS
        • Nov 2005
        • 1251
        I picked this one up and paid ~$70 to switch to a sprung hub disc. It revs nice and has never slipped.
        Originally posted by 325Projectz
        don't listen to the diagram... listen to mr. swiss.
        :nice:
        • kylebes1
          • May 2004
          • 2804
          I thought the m50 had the smaller clutch.
          strike two for me
          • LINUS
            • 2422
            Swiss -
            That Fidanza piece looks quite a bit like the UUC job I have - same concept too to switch to the M5 disc. Good find. If I didn't have a flywheel piece already, I'd grap one of those too.
            Does it use the M5 pressure plate, or the M3 one?
            What pressure plate & disc setup did you go with?
            How many miles have you logged on the setup? Impressions?
            It's not how you handle the good times, but the faith you keep in the bad that defines you.
            • Mr.SWISS
              • Nov 2005
              • 1251
              Originally posted by LINUS
              Swiss -
              I was looking through the Fidanza site and found some pics of the a flywheel that said UUC on it. So I am impressed to believe they make the UUC and it gets reboxed. I love the clutch, at first it was really twitchy and I killed it a few times, but after getting used to it and breaking it in it is good now.
              :nice:
              • thuibers
                • Jan 2005
                • 44
                My engine was rebiult by Dinan and stroked to 3 liters [before I bought it so i don't have any real info]. I am using the stock dual mass flywheel. I do have my old e30 flywheel and starter but I think I want to keep the heavier flywheel to keep the enging idelling smoothly. So I'm thinking a sachs kit [stock?] will be adequate.
