Size of fuel lines under M50 manifold?
  • bwh13
    • Jan 2007
    • 437
    My manifold didn't come with the metal supply or return lines, so I need to either buy some or make up some of my own. What size are they, 8mm or something? Also is there supposed to be an in-line fuel filter on the supply side by the manifold?
  • e30_kid89
    • Apr 2006
    • 489
    if i remember right some guys just run fuel hose as a subsitute.
    why not buy the lines new?
    • matt
      • 3732
      You can put the filter anywhere in the supply side. The stock e30 locations work great.
      I would replace the hardlines, they are an awesome feature when you use them properly.
      They are 8mm OD, but flared. The proper fuel hose is BMW 8x13.
      • bwh13
        • Jan 2007
        • 437
        Thanks. New ones are like $45 for the pair. I'll just buy some 5/16 steel tubing and bend my own...I thought about just using fuel hose, but would rather have metal under the manifold just in case...
        • matt
          • 3732
          Just using hose is likely better than anything you'll bend or flare yourself.
          • Lobstrosity
            • Aug 2004
            • 116
            Or get some from a wreckers? Bit of a pain to remove, but not terrible.
            • bwh13
              • Jan 2007
              • 437
              OK I'll just use some left over braided line I have...thanks
