My CEL light has been on since i fired my car and today i tried to pull those codes to no avail. The Peake tool didnt work. The tool itself works so what could be wrong?
pulling codes
Originally posted by matt View PostDid you try a stomp test?
WTH is this? Are you just screwing with us? What does this achieve, and what is the proble, this is the solution for? If it's a dirty HFM, wouldn't it be easier for you & the motor to R & R after cleaning it with rubbing alcohol?
It's not how you handle the good times, but the faith you keep in the bad that defines you.
Originally posted by LINUS View PostWTH is this? Are you just screwing with us? What does this achieve, and what is the proble, this is the solution for? If it's a dirty HFM, wouldn't it be easier for you & the motor to R & R after cleaning it with rubbing alcohol?
Any luck, Dustin?
I sat down for a few min but i couldnt get the stomp test to work. I need to look at some diagrams to see whats up with port. What all pins need to have power? I get volt in two pins. My car is running really rich and i am not sure i got the o2s on right, i pulled the harness apart when rolling the car so i just soldered the wires together. I might try and fix the running rich part and see if the CEL will go away. Does a lack of o2 cause the car to run rich? there is also slight hesitation from 3-4 rpm.
Originally posted by matt View PostI am pretty baffled by this post... is it a joke I don't get?
Any luck, Dustin?
Please explain, even just a broad overview to get me slightly informed.
Originally posted by rede30 View PostI......... My car is running really rich and i am not sure i got the o2s on right, i pulled the harness apart when rolling the car so i just soldered the wires together. I might try and fix the running rich part and see if the CEL will go away. Does a lack of o2 cause the car to run rich? there is also slight hesitation from 3-4 rpm.
the CEL will light up with a bad or missing o2 sensor. yes, the car will run really rich with an o2 sensor missing.
cheers, jason
Originally posted by rede30 View PostI sat down for a few min but i couldnt get the stomp test to work. I need to look at some diagrams to see whats up with port. What all pins need to have power? I get volt in two pins. My car is running really rich and i am not sure i got the o2s on right, i pulled the harness apart when rolling the car so i just soldered the wires together. I might try and fix the running rich part and see if the CEL will go away. Does a lack of o2 cause the car to run rich? there is also slight hesitation from 3-4 rpm.
I would definitely suggest a new O2 sensor also, and make sure it's hooked up properly. Feedback from the O2 sensor is critical.
Originally posted by LINUS View PostSadly, I'm totally serious. Appearantly I'm so clueless I have no idea what the "stomp test" is.
Called the "stomp test" because you have to "stomp" the pedal quickly.
I have never been able to make it work on my car. If you have a friend with the Peake tool that's the way to roll. Much slicker, plus you can reset the damn oil light. :pimp:
This might be worth a sticky or addition to the Wiki as a lot of folks probably have chronic CEL's that could be fixed relatively easily.
1987 325i Cabrio - SOLD
2014 Chevy Volt
2007 FJ Cruiser
I checked my wiring job on the o2 sensor and everthing looked good but i checked for volt when running and nothing was coming through any wire. I am going to mess around at the relay on sunday. I didnt drive the car but everthing seemed the same when i ran the car with the o2s and with one not plugged in. What should i look for at the relay?
