No Start.
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    No Start.
    Well i put everything together and got ready to start it up, no go.
    I believe i have all the harness cable on right. I used the e30 starter cable, and then to the altenater. Yes the engine is grounded and i get 12v to the power cable on the starter. I dont get power to the Starter/Unloader Relay (pin 15 on both/Black Green) and no power to the Voltage While Starting (pin 18 on both/Black Yellow)
    i jumped power from another source and the starter does work (its also my original starter from the m20). tried different relays with no luck too. does the start go though the DME? just dont know where to start!
    Heres my pin Layout:
  • PiercedE30
    • Apr 2005
    • 4220
    have you checked for power to the ecu? what about the main relay?
    My 2.9L Build!
    • e30_kid89
      • Apr 2006
      • 489
      Is it cranking when you're trying to start it? From what I've seen you wiring is good or should be good enough to get the car running so check the the relays to see if they're all working, then check for fuel/spark. Does the fuel pump prime when in the Acc position? from there check if your Crank Position Sensor is dead. Thats another possible cause for a No Start.
      • BDSax
        Junkyard King
        • Mar 2006
        • 3594
        well, the problem is that there is no starter movement at all. I have been looking at the ETM and i think it may be the k7 underloader relay. i have power to fuse 10 but no power anywhere else for the black/green and black/yellow.
        Main relay seems good. the DME doesnt control the starter, right?
        • e30_kid89
          • Apr 2006
          • 489
          Yup it doesnt. Check out those unloader relays and everything starter related in the ETM. I'm sure after you sort it out that nice kleen motor of yours is going to fire right up.
          G'luck!
          • erik325i
            • Jan 2005
            • 3567
            What ECU are you using? Did you disable the EWS?
            I'd guess the EWS is your problem.
            -Erik
            • BDSax
              Junkyard King
              • Mar 2006
              • 3594
              im using red label 419 (i think)
              its out of a 11/92 car with vanos. Tried new underload relays, nothing.
              • PiercedE30
                • Apr 2005
                • 4220
                does the ignition switch itself get power?
                we fought with an ignition switch issue on our race car and ended up going through like 3 switches, and it would only start if you hit it correctly.
                My 2.9L Build!
                • BDSax
                  Junkyard King
                  • Mar 2006
                  • 3594
                  well, it did work 2 months ago when i pulled the m20. the on position works the radio and the windows but maybe it did just gave out.
                  everything seems to be good too, ill have to test the ignition switch and see.
                  • PiercedE30
                    • Apr 2005
                    • 4220
                    Same thing with our car. Everything worked except for the start position.
                    My 2.9L Build!
                    • BDSax
                      Junkyard King
                      • Mar 2006
                      • 3594
                      does the bentley tell you how to test them? i will have to look it up and check it out tomorrow. Thank you for the tip!
                      • e30_kid89
                        • Apr 2006
                        • 489
                        Before you tackle the igintion switch, did you check all of your grounds, battery voltage and shizz to see if they're all clean? check that as well. Just a suggestion.
                        • FredK
                          • 14762
                          Billy, sorry I didn't call you back last night. I didn't hear the text message sound on my phone!
                          Anyway, I just thought of something. Have you wired up the automatic-to-manual-transmission swap wires? Check this post by Mike B.
                          I used it when I did my swap because like you, my car was an auto.
                          • matt
                            • 3732
                            Duh. I shoulda though of that also, since i'm manual swapping a customer car right now.
                            • BDSax
                              Junkyard King
                              • Mar 2006
                              • 3594
                              well, i did connect connect the wires by the shifter, but maybe i connected the wrong ones. ill have to look at that. i have been studying that ETM page all day!
